Threads: 41
Thanks Given: 82
6
Some lovely person :censored: has broken my radio aerial. Are they easy to change? Haynes didn't shine any light on how to change it for me :dislike:
Threads: 32
Thanks Given: 18
lower the interior light and you can see a 10mm nut, undo that and take the aerial off.
Threads: 41
Thanks Given: 82
6
Thanks Steve - I thought it was going to involve taking all the cupboards out.
Threads: 32
Thanks Given: 18
Ahh, well, it was that easy on my van, not sure about with the modutop
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
If its only the mast, you can buy replacements.
I bought genuine Citroen one off fleabay for £8.
Doesn't look like it unscrews; but it does. With mole-grips and swearing!
When replacing, copper grease on the thread ensures easy removal in future.
Threads: 41
Thanks Given: 82
6
27-08-2011, 01:04 PM
(This post was last modified: 27-08-2011, 01:06 PM by Mike.)
Just done this - was as easy as Steve said
Didn't need mole grips either - just a socket.
Threads: 3
Thanks Received: 4 in 3 posts
Thanks Given: 3
J90 meant the mast i think.
Hey, that´s nice, the base of my aerial is lose, i thought i had to remove the whole front roof first! Just behind the lamp then. The over-the-head shelf is flocked metal sheet isn´t it?
Threads: 41
Thanks Given: 82
6
I have a modutop and when I did it (as above) all I did was remove the light and you will see the nut that holds the aerial on.
