Rear axle Tension rod
Hi all .
I am looking for some advice , I have a 03 2L diesal belingo multispace , which needs the main rear trosion bar changed , citron want £140 for a new one but after some looking and talking around I had some advice to just change the whole rear axle with a second hand one .
It seems the rear axle may already be bent as both rear wheels  tilt inwards from the top .
So does anyone have all or some advice on this problem or where to best source a scound hand rear axle from .
Thanks all Daz
Update;;;Wink)
I have picked up a slavaged full back axle today from a place in Bridgeport Dorset for £120 cash .
Thanks all Daz
When you swap the axle you will need long star drive bits to remove the bolts on the rear mounts, they are the same size as the ones for the front mounts, but are accessed through holes in the axle casting. It is also worth spraying loads of penetrating fluid inside the box section where the axle mounts or the captive nut can spin. (Don't ask how I know!) The manual tells you to disconnect the brake pipes to the rear, but if you get a long piece of string you can loop it over the roof and suspend the calipers or back-plates. I don't think I removed the hand brake cables either. The load sensing valve can also be left connected if you suspend it from the underside. Rear silencer and spare wheel hanger has got to come off though.
Repair of the rear axle on these things is virtually impossible for the home mechanic, a swap is the only answer, I paid £300 for a re-con axle delivered for the sake of a couple of £20 bearings, Chitroen shite!
[-] The following 1 user says Thank You to JohnM for this post:
  • Forddee
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
