  • 13 Vote(s) - 3.08 Average
Help! A wiring problem
Can anyone describe the wiring pathway from the rear tailgate window heater to the front of the vehicle? I have a dead short somewhere probably caused by a screw from fixing a pop top roof on. I'm thinking of trying to find where the wire is damaged.
(18-08-2011, 06:44 PM)lmawilso Wrote:  Can anyone describe the wiring pathway from the rear tailgate window heater to the front of the vehicle? I have a dead short somewhere probably caused by a screw from fixing a pop top roof on. I'm thinking of trying to find where the wire is damaged.
Can you give some Vehicle information
Model, Year etc + your VIN No & RPO Number ( RPO Number Should be on a sticker. Number should start with 09) Mines 09804
(18-08-2011, 06:49 PM)BlueBlingo Wrote:  [quote='lmawilso' pid='9382' dateline='1313693061']
model Berlingo M-S Forte 92
Year 2006
VIN VF7GJ9HXC93351835
Can't see the RPO
First read this link before you d0 anything
http://www.bba-reman.com/content.aspx?co...ot_process
I have not got your RPO but this should be something like your vehicle.Refer attached diagrams
The Positive supply (The wire you suspect) is wire 811( Coloured Yellow) From Pin 9 of plug 16v (Black) at the BSI.
It goes into harness 46 HAB at the rear of the vehicle it terminates at the Green Plug 6V The corresponding wire from this plug to the heater is is 811A coloured Black.
The Earth wire to the rear screen is wire M881X (Possibly coloured Yellow/Green) It connects to Earth Point MC80 (Tailgate Earth) This is situated about 6 inches below the rear screen on the RHS
Item 8120 is the heated rear screen.
Item 8110 is the screen switch
Hope this helps let us know how you get on.
Attached Files Thumbnail(s)
[-] The following 2 users say Thank You to BlueBlingo for this post:
  • lmawilso, ron
thanks
(30-04-2012, 11:30 PM)universallis Wrote:  thanks
Hi, just for your info, your RPO No. is 10774 Confusedalut:
Rear brake caliper piston problem
Yesterday 08:47 PM
Cruise control retrofit
Last Post: E30alex
12-02-2025 08:39 PM
Part ID, what's this for?
Last Post: Muppets on Mars
12-02-2025 12:19 PM
Alloy wheels
12-02-2025 08:05 AM
2011 B9 DPF warning light
11-02-2025 07:13 PM
» Replies: 15
Greetings from Romania
11-02-2025 10:43 AM
Whats Your Berlingo 'Pet' Name.
Last Post: Lokusan
09-02-2025 08:17 PM
» Replies: 32
Indicator/lights Stalk
09-02-2025 06:26 PM
Roof bars and roof box
Last Post: LukeClark
08-02-2025 07:24 PM
Remove Wing
Last Post: ADarkDividedGem
06-02-2025 02:13 PM
