front hub differences
Hi...was wondering how different hubs where, I have a 1.8 petrol and need a drivers side hub as bearing as gone, it's hard to find a part on ebay as most seem to be diesel.... Is there a guru that knows what fits what? To widen my search..thanks
why are you changing the hub if its only the bearing thats gone
Gary. Whats wrong with hubs?
I don't have access to a press so it easy just to swap the hub
(20-07-2015, 09:19 AM)Gary Quarmby Wrote:  I don't have access to a press so it easy just to swap the hub
you dont need a press just a socket the size of the bearing just be carefull knocking out the old one ive only ever done fords and they use taper bearings and they are harder to do. new to berlingos but googled to see what type they where you would need circlip plyers torque wrench to do the job
It's not as easy as that...you need a press to get the spindle out of the bearing and get it out of the hub...they are flush fit bearings and need 16 ton of pressure to remove...I have a mate who as a ten ton press and it won't touch them....the hub nut is a real swine to get off as well...6 foot pole and lots of heat...
I have done one side allready with a swap out of a hub of a 1.8 petrol but there are not a lot of hubs around for them....hence wondering why others would fit...
Yesterday 07:31 AM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
OIL Drip
Last Post: Martinze
10-03-2026 06:08 PM
10-03-2026 02:49 PM
New owner in Bristol UK
Last Post: JPCoetzee
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
