[Brakes] Guide for front brake caliper removal
Hello,my front brake calipers are sticking and i need to remove them and free them up.anyone got a guide for this?
Two bolts and they are off, you could do with a couple of dabs of locktite on each bolt when you put them back on.
A G clamp could be handy to push the piston back in if you don't have the proper tool.
[-] The following 1 user says Thank You to JohnM for this post:
  • AntBerlingo
(15-07-2015, 10:25 PM)JohnM Wrote:  Two bolts and they are off, you could do with a couple of dabs of locktite on each bolt when you put them back on.
Do I have to release any pressure to get the calipers to move?
Slacken the bleed valve to exit fluid there instead of forcing fluid back into abs unit / master cylinder.
(16-07-2015, 09:10 AM)geoff Wrote:  Slacken the bleed valve to exit fluid there instead of forcing fluid back into abs unit / master cylinder.
Clamp the rubber flexible pipe as well while you do it, saves some fluid and bleeding time.
(15-07-2015, 05:52 PM)AntBerlingo Wrote:  Hello,my front brake calipers are sticking and i need to remove them and free them up.anyone got a guide for this?
Hi. What namely sticked? Guide pins or piston?
I'm not sure yet,but as I'm goin along the road at time the brakes are noising when not pressed even
More likely culprit is the wheel bearings !
(17-07-2015, 06:42 AM)brodfather11 Wrote:  More likely culprit is the wheel bearings !
I dont think so Brodfather11 when i press the brakes the noise stops.it only there sometimes.when coming to a stop the brakes screech.A while back one inside brake pad was wearing more than the outside one and they were noising alot.So a garage man freed them and they worked fine for couple months
Points to the pins sticking. Remove them and use a dab of moly grease on the sliding part of the pins. Probably need new pads too if they are scraping. If the pistons can be moved in with moderate pressure then they would OK.
  • AntBerlingo
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
