Threads: 7
Hi.
Well all was going well with my 2005 1.9D Berlingo Van when, I fitted an after market stereo off eBay but couldn't get the audio settings to save, forums suggested swopping the red and yellow wire around which I did and all was great. Audio settings saved, great I thought. Went to the van 6 hours later and everything was all over the shop, windscreen wipers on when I hadn't turned them on, something sounded to be clicking under the bonnet when I tried turning the ignition on, dash lights, then no dash lights. Then pulled the key out of the ignition, made sure lights in off position and side lights are on all round, (barely).
Tried jump leads to no gain and this does not sound to be a flat battery.
Getting it recovered in the morning but does anyone have any idea what this problem might be? (and whether it was the stereo or not, its out of there).
Thank you.
Threads: 7
Hi.
I tried the above, thought I was in business. Tried headlights first on and off without a key, yes. Tried turning ignition and had some dash lights initially but a lot of clicking from under the bonnet like it was shorting on something. Wouldn't start and then lost all the dash lights.
Thanks Given: 188
23
You need to shut everything down and disconnect the battery then follow the reset procedure if you havnt got central locking just skip that bit. If the radio is still connected disconnect that before you start.
Are we there yet?????
Threads: 7
Done it, lights work. But as soon as I try to turn ignition on all I'm getting is the clicking noise under the bonnet and now for some reason wipers came on very slowly mind.
Thanks Given: 188
23
You could try disconnecting the battery and leaving it for a few hours then try a reset. You may have done damage to the BSI unit which controls all the electrical component's. Its under the fuse box to the right of the steering wheel and can be checked out. They are prone to water ingress which causes problems but if it only started when you did the radio it that is more than likely the problem.
Threads: 23
Thanks Given: 50
29
Your battery is flat you need to give it a good long charge
Threads: 7
Not a flat battery as the jump leads should have started it and a flat battery wouldn't put my side lights on for no apparent reason. Thanks anyway though.
Threads: 7
I take it all back Jed, breakdown came out to it this morning and yes it was indeed a flat battery, I asked him why would a flat battery set windscreen wipers off, lights etc and he said for some unexplained reason a low battery causes havoc with the relays and tells them to do all manner of things. The battery on it was too small also, fingers crossed this is all it is now I've put a new battery on it. Thanks for advise re BSI, that was a sensible answer too.
