Threads: 12
Thanks Received: 3 in 3 posts
When I turn on the ignition I get all my dash lights, indictors, radio and blue high beam light but no wipers, lights, heater fan and she wont turn over, when I try to start there is a click from a relay in the fuse box.
I've lost the High power supply, where do I look first?
thanks guys!
Thanks Given: 188
23
Check the battery and charge if needed, did you leave anything on overnight and its flattened the battery.
Are we there yet?????
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
is the under bonnet fuse box connections OK ? , I seem to remember that there were some problems with water/bad connections in there.
Thanks Given: 188
23
Check your earth straps and earth points from battery and power cables from battery to relay and to starter motor. Have you done a load test on your battery? Try swapping battery for a known good one to rule out yours. Failing that lot checking out it could be the starter motor.
Threads: 12
Thanks chaps I'll look again tomorrow and keep you posted??
Threads: 12
Starter motor failed and put the etectrics in to safemode, new starter fitted £197
