23-07-2015, 09:40 AM
Hi guy's,
Just got myself a Berlingo 2012 model.
It was bought with accident damaged to front end.
Started car before I bought it and started it when delivered however it had a fuel pipe/fuel cooler missing underneath from accident so quickly switched off engine.
Car from the begining seemed to have an electrical fault ie windows did not work but i thought that maybe it was because the car was in limp mode due to accident.
As soon as I fixed fuel problem I went to start engine but would not crank. Now shows breaking system fault and auto locking active, then goes into economy mode, also cannot read ecu with obd device which is suggesting to me that it could be immobilser problem.
At some point from buying to repairing fuel pipe problem the battery was disconected by my friend (not sure why?)
I have had auto electrician look at it but he cannot fix it... I beleive he could not connect to ecu either
Can anyone tell me if there is a way to reset things back to normal without me having to take it to main dealer?
Thanks a lot
legepe
Thanks a lot
legepe
