New Berlingo Owner
I have just bought my first Berlingo! Before hitting the road for my first long-distance road trip I wanted to get to grips with all the basics for roadside repairs etc. As I do not have my manual, I cannot see where the specified point is for connecting the jack under the body of the car. Can anyone tell me this? My vehicle is M59 Berlingo (Models dating from 2002 - 2008)
Hi Katie and welcome to the forum. I'm sure someone will be along shortly with an answer to your question.
Hi Katie welcome to the forum. If you look on the sill behind front wheels and in front of rear wheels you will see a small triangle pressed into the sill, your jacking point is below on the seam weld between the bottom of the sill and the floorpan. Your jack has a channel in it to locate it along the seam. It sounds more complicated than it is but once you look at it all will make sense.
  • ron
(25-07-2015, 11:29 AM)Tomcat3 Wrote:  Hi Katie welcome to the forum. If you look on the sill behind front wheels and in front of rear wheels you will see a small triangle pressed into the sill, your jacking point is below on the seam weld between the bottom of the sill and the floorpan. Your jack has a channel in it to locate it along the seam. It sounds more complicated than it is but once you look at it all will make sense.
Thank you so much! This is my first car- so I am trying to educate myself thoroughly before I am to use the vehicle for any long journeys.
K
They are a friendly bunch on here if you get stuck just ask and someone will come along hopefully with the answer. Just in case you havnt seen it open the drivers door and in and between the hindges there should be a sticker. This will give you paint code, tyre size and pressures among other things.
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
