Headlamp converters for Europe?
I've just bought a 63 XTR. Do I need to use headlamp beam deflectors for Europe?
I was told that on my C4 Picasso the beams were "flat" and didn't need deflectors and so I never bothered and in 7 years of France and Spain I never had any issues.
Thanks.
Yes, I contacted Citroën UK about the same thing on my 64 plate XTR and they confirmed that I did need beam deflectors. I have just returned from France having used the RAC version which were very easy to apply and worked brilliantly.
2014 Berlingo Multispace 1.6 e-Hdi XTR ETG6
[-] The following 1 user says Thank You to jayjay2cv for this post:
  • dickl
Thanks Jay. Much appreciated.
Cheers
Dcik
Back in the '70's Renaults had a little lever in the headlamps to change the beam L--R as needed.Surely it would be simpler to have this than risking badly fitted/made deflectors?Some old ideas were good. Sad
Thanks chaps.
True Ron, I had a BMW GS where you could adjust the headlight for Europe.
Today 12:17 PM
Last Post: wbchevron
Today 09:32 AM
Yesterday 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
