trackstar gps to tomtom
hello ...a query regards the citroen added trackstar gps system which i must say i am not that pleased with...from what i have read this is likely to be powered by a male 10 pin mini usb (please correct me if i am wrong)....anyway i was looking for an adaptor to convert this to run my trusty old tom-tom sat nav which is to my knowledge a micro usb
if anyone has found or made such an adapter i would really appreciate tany help ....and I thank you in anticipation
(05-08-2015, 09:13 PM)carloski Wrote:  hello ...a query regards the citroen added trackstar gps system which i must say i am not that pleased with...from what i have read this is likely to be powered by a male 10 pin mini usb (please correct me if i am wrong)....anyway i was looking for an adaptor to convert this to run my trusty old tom-tom sat nav which is to my knowledge a micro usb
I'm sorry I can't give you the exact help I'd like to, as it was nearly 3 years since I converted the cable on mine and it is well buried in the side pillar of the van.
I bought a convertor from CPC (just google it n look at CPC Farnell's website) and it just plugged it in.
I first matched up the connector by googling pictures until I got the names/types for both "sides" of the connector. My TomTom cable was an ordinary USB "A type" connector, but this connected to the van Satnav cable without a hitch, using the adapter.
Be aware the van cable is live all the time, so you need to disconnect/switch off the TomTom if you connect to it (something to do with the tracking system I believe).
Wish I could help more.
Good judgement comes from experience, and experience comes from bad judgement…
2017 Berlingo Multispace Flair 120
2013 C5 Tourer 2.2HDi Excl
Previously:
2012 C5 Tourer 1.6HDi auto
2012 Berlingo Enterprise 1.6HDi Van
2009 C5 Tourer 2.0D
2001 C5 Tourer 2.0D
2001 Range Rover 4.6 Vogue (really!)
[-] The following 1 user says Thank You to Argos69 for this post:
  • carloski
Argos69 ...thank you for your feedback ...i will look at the CPC site and see what i can come up with...again much appreaciated
regards
C
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
