[Engine] 1.6 hdi no power
hello all..new here..glad to see you all. i have an issue with my 2010 Berlingo 1.6hdi. my engine has no power..i believe that it is the turbo which is messing around..it has no shaft play..just a strange whining noise..just have the turbo checked..and they said it is in great shape..overall engine in very good condition..not an oil drinker..no nasty noises..can anyone help pls? and also no check engine light on!thnks Blush
Did they put a code reader on it to check for possible fault codes?? That's the first thing I'd do.
(11-08-2015, 03:39 PM)3rensho Wrote:  Did they put a code reader on it to check for possible fault codes??  That's the first thing I'd do.
no not yet..i thought that as long as no check engine lights..i thought there wont be any fault code..my mistake Undecided
Hello Joy welcome to the forum good to have you with us Smile Check the air filter fuel filter also check the turbo pipe's from the turbo to the inlet manifold for split's or being loose the spilt may only show up under boost pressure.
good evening guys..finally the vacuum pipe was torn apart..changed that and all good..just when shifting gears..the rpm goes up and then returns to normal..what could this be pls? thnks
(12-08-2015, 03:29 PM)Joy Wrote:  gthe rpm goes up and then returns to normal
And it is possible to specify it  in figures?
if am changing gear on 2000rpm..it climbs to 2500 then back to 1700..ex from 2nd gear to 3rd gear  Blush
Try to disconnect clutch sensor... it's not so hard to do by yourself.
There was a such topic in BF:
http://www.berlingoforum.co.uk/thread-4230.html
[-] The following 1 user says Thank You to pk7478 for this post:
  • Andre
Today 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
