  • 8 Vote(s) - 2.13 Average
Radio / CD player
Hi all
If I disconnect the battery, will the stereo require a code? I can't find any info in my paperwork...
Citreon Berlingo Enterprise
1.9 DW Diesel engine
Forestry Commission Green
'55 plate
Haven't tried it on my Berlingo yet but on other cars I've owned it did require a code.
[-] The following 1 user says Thank You to 3rensho for this post:
  • Bryan
On new model radio is re enabled automatically from key signal.
[-] The following 1 user says Thank You to scotsron for this post:
  • Bryan
I thought I'd just bite the bullet so I removed the battery and when I reconnected it, all I had to do with the stereo was reset the date. This was on a '55 Berlingo Enterprise.
Thanks for your replies.
'55 plate
Hi Guys,
Same for me. Disconnected battery to do a job and when reconnected only clock needed attention. I'm pretty sure it all has to do with the key chip!
Regards, El Berlingo
(21-08-2011, 05:07 PM)Bryan Wrote:  I thought I'd just bite the bullet so I removed the battery and when I reconnected it, all I had to do with the stereo was reset the date. This was on a '55 Berlingo Enterprise.
On MK 2`s Vehicle VIN No is programmed into Radio.
[-] The following 1 user says Thank You to BlueBlingo for this post:
  • Bryan
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
