I've only gone and bought a Berlingo?
Just dropping in to say Hi for the first time..
Have just bought a 55 plate 1.9D Berlingo and although it seems fairly tidy for its age, I just know the gremlins are probably lurking in the background somewhere.
Seems like a nice small van to me, wish I had bought one sooner.
Will now go and bury myself in the technical forums and check out what problems are likely to bite me in the wallet sooner or later!!
Any pointers on what bulbs are required for the central multi function display?
Mine looks like there is only 1 working on the r/h side - is that a simple fix?
Cheers
Well congratulations on the purchase and welcome to the forum. Lots of very helpful info on these pages. Post some pix of the new Bingo when you get a chance.
[-] The following 1 user says Thank You to 3rensho for this post:
  • Robbo62
Hello Robbo62 welcome to the forum good to have you with us Smile look through the post if you can't find what your looking for just ask
  • Robbo62
Hi Robbo welcome to the forum have a read of this thread for your bulbs and how to do it http://www.berlingoforum.co.uk/thread-54...ight=bulbs
  • Robbo62
Hi Robbo & welcome.If it's done over 100,000 miles,check the valve clearances as they tighten up causing bad starting.It's a camshaft out job so if you're anticipating changing the belt & w/pump,do the valves first.Changing the trans oil with synthetic is also a good idea as it's not normally changed.Enjoy your Berlingo. Smile
  • Robbo62
(14-08-2015, 06:43 PM)Tomcat3 Wrote:  Hi Robbo welcome to the forum have a read of this thread for your bulbs and how to do it http://www.berlingoforum.co.uk/thread-54...ight=bulbs
That looks pretty straight forward and definitely in my comfort zone!
Bit confused about the bulbs though - From what I understand these are a 286 (T5) fitting Yes / No?
They seem to be everywhere on eBay rated at 12V / 1.2W, but I have seen others at 12V / 0.4W
Other owners talk about swapping them out for LED's
Don't want to melt the MFD on my first attempt.!!
Any information is appreciated
Yes you want T5 286 12v 1.2w bulbs, you can change to led bulbs but there is a lot of crap cheap rubbish that doesn't last long so beware.
  • Robbo62
(15-08-2015, 06:51 AM)Tomcat3 Wrote:  Yes you want T5  286 12v 1.2w bulbs, you can change to led bulbs but there is a lot of crap cheap rubbish that doesn't last long so beware.
Yes agreed,be careful, LED bulbs can be a bit of a problem,if they werent originally fitted best stick with the original light bulbs would be my advice. Berlingo's are great vehicles,do exactly what they say on the can ,but oh so dull to drive.Ive had mine for 6 years and its been totally reliable and returns 40 ish to the gallon.[ 1.9 diesel ] It carries full 8 x 4 plasterboards on the roof ,takes wifey shopping,and takes doggy out on sundays,what more can you want !!!!!!!! Mmmmmm
[-] The following 1 user says Thank You to bikergraham for this post:
  • Robbo62
Timing belt change interval
Today 03:06 PM
» Replies: 19
B9 tailgate lock
20-04-2025 01:58 PM
Tie rod end bad almost every year
19-04-2025 10:56 AM
Water Leak Boot (tried a number of suggested fix...
19-04-2025 10:49 AM
AC Compressor Clutch
Last Post: tomhick024
18-04-2025 05:36 AM
Cruise control retrofit
17-04-2025 08:15 PM
Exhaust bracket
Last Post: timpascoe
17-04-2025 12:29 PM
Last Post: Mehal888
15-04-2025 12:57 PM
» Replies: 75
Washer Pump *Brand New unopened*
Last Post: Antdad
13-04-2025 05:47 AM
2.0 hdi clutch
Last Post: Martinez
13-04-2025 01:11 AM
