21-08-2011, 06:10 PM
Hi, I've got an 04 plate berlingo, and was running a bit hit and miss, sometimes would run fine all day and the i would get the occaisonal flat spot, but was quite noisey up top, so took it in to be looked at, they said due to millage should start with a new timing belt, after this was replaced, van ran really rough, and wouldn.t run under load and kept cutting out, so mechanic said needed new fuel pump.
So took old pump to deisel specialist, said in most cases its fuel solenoid, so this got replaced, but now berlingo won't start at all been to 2 mechanics and still no further, both say there,s only a trickle of fuel at injector, does this mean the pump does need replacing. but the diesel specialist said if the van was running before, it should be running as before with the new timing belt fitted.
any help on this would be greatfully appreciated.
alut:
