Burning readable music CD-s for Berlingo
Hello everyone!
Do you guys know how to burn readable CD-s for 2006 december Berlingo? I tried to burn with Windows Media Player but it didnt play in the car. Anyone have experience on this issue?
(20-08-2015, 09:52 AM)doofer Wrote:  Make sure it's an audio CD, not a load of computer files - it should be if you used WMP.
Use a CD-R - many CD players won't play CD-RW disks.
Thank you for your response.
I am using CD-R discs to burn audio CDs. They have capacity of 700mb and speed 52x. I burned with windows media player, yet the disc doesnt work in the car.
You may need to use something like these:
http://www.amazon.co.uk/Maxell-MUSIC-XL-...recordable
I don't know what the difference between normal and Audio CD-Rs are, but I do know that they are different. Also, more expensive...
None of the above, the solution is simply to use a better program and not Windows Media Player. Make a .cue file and burn it. You don't need Audio CD-R, CD-RW also works fine. CD-RW is the best option as you will quickly get bored out of the 20 songs in a week. Size of the disc also is irrelevant.
http://forum.imgburn.com/index.php?/topi...g-imgburn/
[-] The following 1 user says Thank You to Kokain for this post:
  • whitebus
CD players can be choosy as well. I have a multi player that will not look at recorded discs but a single deck on the same system will play anything you put in it. It might be something to do with the laser azimuth or some other magic.
ServiceBox
Last Post: nonce
Yesterday 03:28 PM
Limp mode, no other symptoms.
Yesterday 11:37 AM
Adding aircon oil after component replacement
Yesterday 11:23 AM
Centre Air Vent On Dash
06-07-2025 10:50 AM
05-07-2025 11:41 AM
» Replies: 36
2.0 hdi clutch
05-07-2025 06:20 AM
Solenoide, Wastegate
05-07-2025 02:27 AM
All NS front head lamp bulbs blown?
05-07-2025 02:15 AM
Power steering Leak
Last Post: AugustinoHippo
01-07-2025 11:09 AM
install other safetywall
Last Post: mikeh79
01-07-2025 09:48 AM
