New alloys
Finally got the alloys I wanted after 5 years. Only problem is the tyres at the rear are 1-2mm away from the inner arch but it will have to stay like that cause I don't like spacers.
[-] The following 1 user says Thank You to berlingo power for this post:
  • silverfox
really smart wheels & I'm not an alloy wheel fan.
(20-08-2015, 05:41 PM)berlingo power Wrote:  Finally got the alloys I wanted after 5 years. Only problem is the tyres at the rear are 1-2mm away from the inner arch but it will have to stay like that cause I don't like spacers.
Really nice set of wheels you got there
Nice looking alloy's set the van off drive the van with a load in see what happens when you corner or go over bump's pot hole's being the UK see if they touch the arch if they do spacer's only 5 mm and longer wheel bolt's or narrower tyre's
It's got about 200-250kg of tools in it all the time seems okay, the rear 2 do make a strange wheel bearing kind of noise at speed but maybe it's just the air flow trying to squeeze through that 1mm gap lol
What size and offset were they?
Very nice looking wheels you got!
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
