Arduino oscilloscope for automotive sensor diagnostic
Threads: 13
Thanks Received: 139 in 113 posts
Thanks Given: 162
18
It is finally here. It took me almost 3 months to learn, arduino, processing... (never programmed anything...)
Another 3 months to compare data with real oscilloscope...
Please check out : http://www.instructables.com/id/OFFscope...card-fast/
If you have any questions... I'm here....
Best regards,
brajomobil
Threads: 52
Thanks Given: 87
5
Wow, many, many thanks brajomobil for posting this. I had been waiting for this since you mentioned a while back that you'd be working on this project.
The following 1 user says Thank You to 3rensho for this post:1 user says Thank You to 3rensho for this post
• brajomobil
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
Interesting.
This is a single-channel 'scope, though?
It might be better to get 2 channels, even if it means dropping the sample-rate quite a bit.
Threads: 13
Thanks Given: 162
18
(21-08-2015, 12:03 PM)Gadgetman Wrote: Interesting.
You can log all arduino analog pins. (6 channels) .But sampling rate drops quite a bit
It is not a problem for slow sensors. e.g. ABS . For fast signal arduino UNO is capable
only for one channel. I am running some tests with arduino DUE and probably will manage
to get usable oFFscope dual channel. Just need to find time...
Best regards,
brajomobil
The following 1 user says Thank You to brajomobil for this post:1 user says Thank You to brajomobil for this post
• ron
Threads: 20
Thanks Given: 2,126
18
(22-08-2015, 08:17 PM)brajomobil Wrote: (21-08-2015, 12:03 PM)Gadgetman Wrote: Interesting.
Best regards,
brajomobil I wish I could understand the practical side of electronics like you guys.I retired just as the electronic era took over.
Strawberry flavoured windows
Threads: 11
Thanks Received: 73 in 67 posts
Thanks Given: 45
8
I know how to use a slide rule !!
Threads: 147
Thanks Given: 263
11
Wow, very impressive. Thanks for posting
The following 1 user says Thank You to Andre for this post:1 user says Thank You to Andre for this post
• brajomobil
Threads: 48
Thanks Given: 4
20
Ron; it's never too late to start...
I recommend the Parallax WAM (What's A Microcontroller) kit and book as a good intorduction.
The book can be downloaded on their site, so no need to spend cash, yet.
https://www.parallax.com/product/28152
And if anything is unclear, they have the best forum around.
Note, their Basic Stamp II that is used in the book may be a mite expensive, compared to an Arduino, which is true. And that is really why those pesky Italians made the first Arduinos, too.
(Both operate on 5V, though, so a circuit design used in the book can easily be adapted for the Arduino)
I think RS-components have most Parallax products in their inventory.
Threads: 23
Thanks Given: 50
29
23-08-2015, 11:06 AM
(This post was last modified: 23-08-2015, 11:08 AM by Jed Clampit.)
OVER MY HEAD
Threads: 23
Thanks Given: 46
5
You and me both Jed ..
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
