16" & 15"Wheels and tyes
I have a 2010 XTR with 215\55\16 tyres. I have my winter tyres off my old 2004 Multispace which were 185\65\15. The wheel and tyre combo will fit the XTR but are not as tall when you put them side by side obviously, will this effect the gearing and speedo reading because of the different size ratio or will it make hardly any difference ?
yes it will but not that much the van version uses 195/65/15 standard.
Remember to check load capasity also. I used Xsara's winter tyres on Picasso and had to put 3 bar pressure that they where drivable.
(25-08-2015, 03:58 PM)Pid Wrote:  I have a 2010 XTR with 215\55\16 tyres. I have my winter tyres off my old 2004 Multispace which were 185\65\15. The wheel and tyre combo will fit the XTR but are not as tall when you put them side by side obviously, will this effect the gearing and speedo reading because of the different size ratio or will it make hardly any difference ?
OK Thanks for the replies. I will use my 15" rims /tyres for the winter here in Central France.
There are many tyre size comparison sites such as http://www.tire-size-calculator.info/
Using the details you give comes up with a 3.4% difference.
[-] The following 1 user says Thank You to Solent for this post:
  • Pid
Pressures seem to make a big difference with the berlingo. Had mine a week now and TBH I wasn't impressed with the handling, seemed very vague, to the point I was thinking the tracking was out or I had a ball joint away!
Checked the pressures when I filled her up today, 30 all round, upped them to the recommended pressures and was amazed at the difference in ride, Very stable now. Berlingo pressures seem quite high compared to other cars Ive had, probably down to the van base?
Today 04:31 PM
Today 11:13 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
