  • 7 Vote(s) - 2.86 Average
Replace the dieselfilter ?
i have one question
, do anyone konw if there is a water draining plug on the diesel filter at the new dv6 engine euro 5 spec (8 valve) . And if you should change the filter how do you fill it , cant se any hand pump on this car . Is ther a electric pump in the fuel thank ?
(22-08-2011, 07:56 PM)Berlingo Norway Wrote:  i have one question
It is a pump on the top of the filter , and the draining plug is an electric connection on top of the filter lid , just turn it and lift it slightly ,,,, ti has an guiding sleeve that lifts it,,, but tis a good idea to assist . No need to break the plastic parts .
To replace undo fuel hoses and electric connections, undo securing bolts and lift the filter unit out .. Then undo 3 screws on the lid and replace the metal filter cartridges. mount it back in to the car and use the hand pump on the lid until the filter is full , pumping gets more heavy
Berlingo is a lifestyle !
[-] The following 1 user says Thank You to Berlingo Norway for this post:
  • Ol'Jeffers
Yesterday 03:36 PM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
