Hello my name is Loren and My partners Name is Nev and we have just purchased a second hand 2004 Citroen Berlingo 1.4i petrol and we brought it as we both run a karaoke business and needed the room to carry our equipment. since picking it up we have had it to two different garages withthe engine warning light coming on and they have guessed what is wrong with it and have not told us what the reason for light coming on is, there were past history codes on the ECU and they have been cleared and some have come back the codes they foundrelavant codes relating to the MAP Sensor, Intake Air Sensor, Cylinder Misfires, but they could not tell us what the problem real is, they removed the codes and some came back, they cleaned the MAP Sensor and fault still present, removed coils and plugs from the vehicle and inspected they seemed to be ok at time of inspection, Air box was not secure and sealed so removed and refit and re tightened the attached hose clamp fault was still present. The vehicle report said the Air Box is Damaged and Tappat Cover Gasket is Leaking. Could anyone help us please with what codes these would relate to and possibly what to do to fix these problems. Thanks Loren & Nev.
Threads: 52
Thanks Given: 87
5
Hello Loren and Nev and welcome to the forum. It would help if you could list the codes that are recurring. Then I'm sure someone will be along to give you some advice.
Threads: 52
Thanks Given: 87
5
Perhaps someone will be along that can give you some pointers from your description of the problems. A basic code reader can be had pretty inexpensively. I use a smart phone app called Torque and my phone is paired with a bluetooth dongle attached to the car. If you have a laptop, a program called DiagBox is an option (along with the car interface) but that would be a bit more dollar wise.
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
Hm...
With so many different faults showing up, I'd look for a common denominator. Maybe damage to the wiring loom?
hi, have van booked in at the citreon dealer here for tuesday the 8.9.2015 to get it checked over to see if they can fix it for us will keep you updated on outcome thank you everyone for your responses and assistance it was greatly appreciated. Loren and Nev
hi all,
just an update on the berlingo, we were taking the berlingo to a citroen dealer to get looked at on hte 8th september were 11kms away from our desination when car stalled nev pulled the car over to side of road out of traffic went to start car again and smoke was bellowing from under bonnet so turned it off again and got our stuff out of car and up it went on fire was total write off so no more car burnt whole front end motor was sitting on the ground all burnt out not repairable the accessor said it was electrical and worte it off as a total loss this happened at 7.30am on 8th September, it was very stressful having to stand there and watch it burn, and being so far away from home was even more stressing as to how we were going to get home ended up getting a hire car through our insurance now we have a toyota camry. So thanks everyone for the help it was greatly appreciated this will be the end of our time on the forum as no need to get on here anymore. we brought some locks on Ebay for the van and they arriveds after the van went up in smoke so now have four locks no van. Thank you Bye.
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Wow, that's a shame! Least the two of you are OK.
