[Transmission] Gear selector bush ?
Hi all , on my way home yesterday my gearbox selector failed ! . the three linkages seem OK but the selector ball jumps out of the socket on the gear change bar underneath. Has anyone had this happen and did a replacement selector with the bush attached remedy the problem or do I need the whole assembly ? , also do gsf or eurospare do the parts I require ? Thanks in advance ,Mick
If the rod ball joints are all good, check the pivot fixing for the ball itself
(30-08-2015, 04:41 PM)Col Wrote:  If the rod ball joints are all good, check the pivot fixing for the ball itself
Hi col , the pivot is a bit loose? Play up and down and slight side movement ? Would this cause the problem ? . thanks for your help mate
If there is enough movement in the pivot for the ball part of the linkage, then yes, it could seperate. I have seen it once before.
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
