Threads: 3
Thanks Given: 1
Hi, my partner quiksilvers heater blower doesn't function properly. It has the usual symptoms of not switching on and occasionally coming on when it wants too, but even when it comes on and blowing full it sounds like it's working away but virtually no air is coming out of the vents as if somehow the passage for the air is blocked.
Any ideas as my local garage told me it would be expensive for them to remove the dash to investigate and with winter approaching it will be required soon in Scotland.
Thanks for any advice
Regards
Marc
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Check the pollen filter. It may be blocked (would also overheat the resistor pack)
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• Sweeneymarc
Threads: 3
Thanks Given: 1
Great I'll gave a look thanks
Threads: 3
Thanks Given: 1
It seems from other research on here that it doesn't have a pollen filter as it's the non aircon one a 2006. Back to the drawing board, thanks for the suggestion anyway
Threads: 23
Thanks Given: 50
29
Look in the front scuttle tray by the wiper's where the rain water goes the in let vent for the heater fan may be blocked with muck and old leaves
Thanks Given: 188
23
Just a thought You could try a smoke match in the intake to the blower or pollen filter then try all the vent and blower settings to give you some idea where the ducting could be blocked or become detached.
Are we there yet?????
Threads: 20
Thanks Given: 7
15
I had a similar problem with my Bipper - in that case it was the numpties at Peugeot had damaged the pollen filter cover and air was just blowing out behind the dash and not the vents.
Sure some of the ducting hasn't worked loose somewhere?
Threads: 4
Thanks Received: 20 in 19 posts
Thanks Given: 5
Have you checked the cables on the heater controls. Maybe unclipped and not operating the internal flaps ?
