In tank fuel pump
Hey can sumone tell me can u remove the fuel pump I'm the tank with out takeing it off the rear of my 2.0 hdi 03 plate berlingo van  has flooring down so can't see or does the tank need to be takeing off to do as my pump in the tank is knackered tryed everywhere on the internet can't find any info on it save me takeing the floor up
The tank comes out from underneath. Don't think there is anything that needs the floor lifted.
Okay thanks so the tank needs to cum off to replace the fuel pump in it
[-] The following 1 user says Thank You to N50pug for this post:
  • DAVEG55
Surly sumone must know on here if u can take the pump out from the top in side the van or does the tank need dropped to take it out  Confused
I havent seen an access plate in the floor of a Berlingo so i suspect its a tank down job.
According to the Gospel of Haynes, Chapter 4c, sections 7, you must first divine the make of your fuel Injection pump.
If thy scrying reveals it's true name to be Siemens, thou hast not a fuel pump in the aft of thy conveyance.
Though, if the name is Bosch, thou should meditate upon the truths revealed in blessed chapter 4A, section 8 and 10.
Dropping the tank is an involved operation, and it's easy to damage something. I really suggest getting hold of the book.
Haynes Workshop Manual 4281, Citroën Berlingo & Peugeot Partner, 1996 to 2010(P to 60 registration) Petrol & Diesel.
Last Post: Alberts elbow
Today 10:11 PM
Today 09:32 PM
Today 05:46 PM
Today 05:17 PM
Potential Purchase!
Today 03:03 PM
Diagbox 7.57 download
Yesterday 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
