Servicing.. Home or Dealer?
Got another service coming up for 100k. Have done servicing at dealer since new but van is now 6 years old.
Question is do i service at home (myself) or Dealer this time? Its due a small service so oil change and filters. I can do it but as it's only £175 shall I just get dealer to do it?
PS don't need belt done at 60k.
All your opinions welcome.
Have a look at http://info.citroen.co.uk/servicing-offe...222#sticky
Click step 2 and it shows what's done
£115 for this service, save you getting your hands dirty Smile
[-] The following 1 user says Thank You to Trevor for this post:
  • osborneelectric
My dealer won't go lower than 175. Thus my reason for home service option. If it's just oil easy but the filters are the confusion for me
Hmm still debating it..
Iv just bought a 05 reg no service history coming up to 100k would I be better going for the extra service thanks just oil and filter change anyone?
Sent from my SM-G920F using Tapatalk
If it has no history,I'd give it a good birthday.All filters & oils(eng & trans),brake fluid & oil everything.Check timing belt & valve clearances.You can have the afternoon off. Big Grin
Lol cheers citroen will do the full for 195 so il book it in cheers
(06-09-2015, 02:59 PM)osborneelectric Wrote:  My dealer won't go lower than 175. Thus my reason for home service option. If it's just oil easy but the filters are the confusion for me
Are you not using a Citroen dealer? If you are I would think they should abide by Citroens web site
sorry did not realise your are using a Pug ...
The stamp in the book always means something when it come's to sell ring around i'm sure you will find a Citroen dealer that will do it for less Pug like to charge more for some reason  Sad i call it social mugging
I work as a Courier and have done all my own servicing on my vans over the past 11 years. I will use a non-Citroen garage for major stuff like cambelts, clutches and gearboxes, but I'm going to have a go at a cambelt change for the first time on my current van when it's due. I change disk pads and disks when needed, and have changed front coil springs and an exhaust manifold gasket on my last van.
I'm amazed that Citroen charge £170 for what is basically an oil and filter change. An oil filter costs about £6.50, and the fully synthetic oil is about £6 a liitre (you need 3 litres for a 1.6 HDi), total = less than £25!
Jed mentions the value of dealer service stamps for boosting trade-in values, but that doesn't matter to me, as I drive such high mileages, that my van has little, or no trade-in value anyway lol! (I cover 70,000+ miles a year!). I keep my own service history, where I record date, current mileage, target service point mileage, and what I did on my van.
I once had a turbo disintegrate and sieze a Berlingo engine during the warranty period, and my dealer tried to wriggle out of responsibilty for it by pointing out my lack of Citroen dealer service history. He claimed that servicing had to be done by a qualified mechanic who was VAT registered. His heart sank, when I showed him that I WAS VAT registered (for courier work), and my Army record book showed that I was a trained "Plant Operator/Mechanic". The result was a new engine courtesy of Citroen UK!
[-] The following 1 user says Thank You to CourierJim for this post:
  • osborneelectric
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
