Fault codes P0401 & P0409
These have been bugging me for a long time. Had both codes P0401 and P0409 for a while on my OBD and they won't go away. New sensor, cleaned and refitted the EGR but don't want to go down the new EGR route as they are 200 and scrapyard won't sell them! Any ideas?
(06-09-2015, 03:01 PM)osborneelectric Wrote:  These have been bugging me for a long time. Had both codes P0401 and P0409 for a while on my OBD and they won't go away. New sensor, cleaned and refitted the EGR but don't want to go down the new EGR route as they are 200 and scrapyard won't sell them! Any ideas?
What engine you have ? Do you have lexia?
Generic OBD code can be misleading...
1.6 hdi. Lexia not yet. Code p0401 is the stickler
(13-09-2015, 08:00 PM)osborneelectric Wrote:  1.6 hdi. Lexia not yet. Code p0401 is the stickler
Check if EGR valve is moving freely . Separate lower part from upper. Turn by hand. Check for sticking.
Here is more info: http://www.berlingoforum.co.uk/thread-12042.html
Best regards,
brajomobil
Also check electrically. If it's not powered, it won't move.
Thank all for replies. Got that one cleaned and sorted. Now I'm seeing P0105? MAP sensor? Any clues? Thanks
Some of the crap dislodged from the EGR ended up on the MAP?
Hi there
Did you try to clean all errors in your OBD after install the sensor and reffing of the EGR Valve?
The ideia is to clean all erros and then put the engine working again.....(maybe you did that already)
I had problems with the EGR valve and The sensor that measures the rotation on the camsahft
(14-09-2015, 08:18 PM)osborneelectric Wrote:  Thank all for replies. Got that one cleaned and sorted. Now I'm seeing P0105? MAP sensor? Any clues? Thanks
Yes. Please plug in Lexia and you can see what is the % opening of the EGR when P0105 occurred.
Then you can rule out EGR. You can also check/change MAP sensor, but I doubt faulty sensor is the problem.
Probably EGR is faulty and it is opening too much causing MAP to report P0105
You can test MAP : http://www.berlingoforum.co.uk/thread-10221.html
[-] The following 1 user says Thank You to brajomobil for this post:
  • osborneelectric
Yesterday 02:50 PM
Yesterday 02:31 PM
Yesterday 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
