Threads: 5
Thanks Received: 3 in 3 posts
Thanks Given: 8
We've had a few comments about features that Citroën have cut from the Berlingo in the name of economy or profit, but my December 2014 Berlingo has one very useful feature which I've only just discovered. I switched on the ignition yesterday and got a 'ping' warning. There was a message saying my tyre pressures were too low. I had no idea as I admit to having been lax in checking my tyre pressures. Three of the four needed inflating considerably. Yes, I should have known but didn't. So a useful, clever feature I didn't even know my car had. I've no idea how it works - I'm sure forum members will soon tell me. The handbook rightly says the device is no substitute for regularly checking tyre pressures. True. So, thanks Citroën. I promise to keep an eye on the pressures in future.
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
Each valve has a little electronic unit that sends a signal to the monitoring computer.
It is law now that all new cars have it, so the price of replacement valves has already started to tumble.
Government introduced this legislation to reduce emissions, as apparently low tyre pressures contribute significantly to this.
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• tezzerh
Threads: 27
Thanks Given: 20
13
Check the valve body to the alloy with some soapy water, I've had two so far that were slowly leaking. The Tyre Pressure Monitor is about the size of a matchbox sitting inside the well of the wheel and the nipple is part of it, sealed by an O ring, therefore the valve body can't be pulled out like a conventional one.
If you have any tyre work done make sure they are aware of the TMPs as they can easily be destroyed if they don't take care, new ones are expensive and need to be matched to the car computer.
The following 1 user says Thank You to Solent for this post:1 user says Thank You to Solent for this post
• tezzerh
Threads: 43
Thanks Received: 410 in 367 posts
Thanks Given: 137
31
There is a different way of TPMS , it works through the ABS sensors and compares the wheel rotation , the idea is if a tyre is slightly flat/underinflated the difference number of rotations between the wheels trigger the warning. ( I think its called non direct TPMS ? )
It can take a lot of miles before it decides to show an alarm.
Skoda and presumably VW/Audi uses this system and does not have sensors in the wheels.
Threads: 12
Thanks Given: 16
37
To improve fuel efficiency mostly I think.
