Front bumper fog lights
Smile
HI EVERYBODY ,CAN ANYONE TELL ME IF I CAN FIT FRONT FOG LIGHTS INTO MY BUMPER IT DOESNT HAVE THEM AT THE MOMENT BUT WOULD LIKE TO FIT IF I CAN AND WHERE CAN I GET THEM FROM ?THE VAN IS A 62 PLATE MANY THANKS DERZO
You would need the switch and the facility enabled in the BSI. That is assuming the loom has the wiring for fog lights.
Failing that, you would need to run your own wiring, fuse and switch.
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
