Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
Hey guys, when taking a BSi unit from another 1.6 hdi can I confirm its just the BSI unit, ECU unit, and key from the donor vehicle I will need for it to work in my van with no recoding necessary?
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
The doner vehicle should be the same as yours, otherwise you may have to re- program things like electric windows if yours has them and the doner doesn't. Make sure BSI numbers match yours. Will have a code something like BSM B3 on it, otherwise you may have a problem with plugs fittings
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• whitebus
