Disconnecting battery- BSI reset?
Planning on whipping front seat out to fix base cushion as it has collapsed and feels like you're sitting on the floor- obviously this requires disconnecting battery for the seatbelt pretensioners.
If I do this will I need to reset BSI when I reconnect battery? This scares me a bit, as the door switches have been disconnected (can't find connectors in door pillars) which are needed to trigger BSI?
Or am I just being paranoid?
changed battery today, didn't need to do any reset, not sure if that is any use though....
[-] The following 1 user says Thank You to miccheck1516 for this post:
  • minisandfords
You will be fine just turn off the radio and don't have the ignition on when you connect/ disconnect.
  • minisandfords
Thanks will bear that in mind!
Use the 3 min rule to allow the BSI to go to sleep before disconnecting.
You mean take key out and leave car for 3 mins beforehand?
(18-09-2015, 08:38 PM)minisandfords Wrote:  1/ Planning on whipping front seat out ....... this requires disconnecting battery for the seatbelt pretensioners.
2/ will I need to reset BSI when I reconnect battery? This scares me a bit, as the door switches have been disconnected (can't find connectors in door pillars) which are needed to trigger BSI?
3/ Or am I just being paranoid?
1/ No
2/ No
3/ Yes
4/ Just for reference I've done this myself in the past ( seat swop ).
  • minisandfords
Open bonnet take key out & shut door and leave for 3mins before disconnecting battery
  • minisandfords
Job done! Front seat cushion had collapsed and felt like was sitting on the floor, done an "alternative" repair to the seat using wire running between the frame!
A lot comfier and firmer now.
Just tackling central locking now- a bit trickier!
didnt work for me
Last Post: JPCoetzee
Today 03:52 PM
OIL Drip
Today 01:49 PM
Today 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
