Threads: 5
Thanks Received: 1 in 1 posts
do installing adjustable fuel pressure regulator does any effects on berlingo 1.9d Dw8 engine?
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
I'd like to see you find one! These haven't got a fuel rail
Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
Welcome to the forum , En Tian.
Are there many Berlingos in Singapore ?
Are you wondering if installing a adjustable fuel regulator makes any difference to the DW8 engine. ?
As Col above said they don't have one . I don't think they need one
Threads: 5
There is a handful, quite easy to find 2nd hand spare, thanks alots for the advise, tot of making it more powerful.
-I have customise my stock air filter,cut away air reasonator. Remove the grill that is behind the logo, drill plenty of holes so air will flow in when I drive.
-Tension my throttle cable, grease my clutch cable, remove my gearknob & sock & grease inside.
-Pulling off the rubber tube that connect at the electronic vacuum regular.
-Replace with coolant in the radiator
-wonder is there still anything I can do to make it more powerful?
Threads: 48
Thanks Given: 4
20
Make it more powerful?
It's a 1.9d?
Swap the engine for a 1.6HDi, or even the 1.4i Gasoline engine... ;-)
How many Km/miles has it gone?
It may need to have the valve clearances done.
Threads: 5
Yup 1.9d Dw8, will not engine swap, would rather sell & purchase mk2 1.6hdi or Mk3, due to the Coe in Singapore. But wonder anyone tried the intake air temp (iat) mod on 1.9d dw8 before?
Threads: 5
Thanks Given: 3
19
24-09-2015, 07:37 AM
(This post was last modified: 24-09-2015, 08:22 AM by Col.)
Yes that COE is very expensive. Is it the same price for vans? Have you got full use or just the weekend one with red number plates?
Quite honestly, any simple mods you make will yield very little power due to the design of the engine.
Those 1.9's were always a bit slow. You could use the 306/406 XUD 1.9 turbo engine for more power, or turn up up the fuelling on the pump, but you would fall foul of the Singapore emissions regs, and I'm not sure what the penalties are.
The turbo route is probably the best option.
Threads: 5
It's under the cat c commercial vehicle, normal plate can use all day long, just renewed it for another 5 years. In sg, commercial vehicle can only use max 20 year including renewal Coe, after tat force to scrap, other countries like our vehicle very much cos mileage low as sg is a small countries. U mean my current mechanical fuel pump Lucas able to turn up? Almost cos higher idling right?
Threads: 5
Thanks for sharing the video, yup it will fault the emission, jus tot hw I can adjust my fuel delivery ? Maybe I can adjust back during inspection....I'm living at Bishan North area.
