Threads: 6
the radio in my citreon berlingo mulispace flashes rds all the time and has very poor reception any ideas why this is happening
Threads: 11
Thanks Received: 73 in 67 posts
Thanks Given: 45
8
The radio data system is looking for a signal to tune the radio into,so if there is no signal it follows that the RDS will flash.I would suggest you look at the aerial connection on the rear of the radio,the aerial cable,and or the earth connection from the aerial itself to the body of the car.Are you in a place where there is a signal at all ? Do you have a metal garage roof ?
Threads: 67
Thanks Given: 237
50
Can you just deselect the RDS ?
Serieal Berlingo owner
Thanks Given: 188
23
If I remember right you tune the radio using manual setting, it works if you are in one area all the while but if you are travelling distance you will have to retune the manual setting.
Have you got the standard aerial on or a trendy but useless short one.
As Graham says check connections especially the roof mount as water tends to get in there and corroded the joint.
Are we there yet?????
Threads: 16
Thanks Given: 46
5
The radio should search & find stations & if you put them in the memory the rds will tune national stations like Radio2 etc wherever you are. If you are in a remote part of Wales you may be in a poor reception area, If you are driving in mountainous & remote areas reception of even the national stations can be poor. Should be ok in urban areas & main roads though.
