Threads: 52
Thanks Given: 87
5
Over on Berlingo.org I've seen discussions about having a so called "Scandinavian mode" activated by the dealer. Presumably keeps dipped lights on while driving. Anyone heard of this being activated or know if it can be done with a Lexia?
Tom
Threads: 16
Thanks Given: 46
5
Daytime running lights mode where headlights come when you start up, normally supplies a lower voltage to headlights to preserve bulbs. Actually switching on lights supplies full voltage. This has always been the case on cars supplied to markets that require daytime running lights.
So if you could activate this it would be good to check that reduced voltage was being supplied or you would be replacing bulbs more often.
Threads: 52
Thanks Given: 87
5
Thanks for that tip. Hadn't considered that point.
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
3rensho.
This can be activated using Lexia.
There's an option in BSI, called "Day running lights".
I did it several weeks ago.
You mean this?
The following 1 user says Thank You to pk7478 for this post:1 user says Thank You to pk7478 for this post
• 3rensho
Threads: 52
Thanks Given: 87
5
HI PK. That's what I was referring to. Many thanks. Do you know off hand if this mode run's the lights on a lower voltage (as mentioned above) to extend the bulb life? I ordered a Lexia today.
Tom
Threads: 52
Thanks Given: 87
5
Danke PK.
Threads: 52
Thanks Given: 87
5
Vielen Dank PK. Gut zu wissen.
Tom
