[Brakes] Brake light fault
hi i just found out my brake lights dont work....
i tryed
 bulbs there good
fuse i cant find for
wires are looking ok
Pressure switch on brake cylinder?
aye were is that located
Have a look on the brake pedal its probably a faulty switch something like this http://www.ebay.co.uk/itm/Febi-Mechanica...51ca873d3a
yes i tryed a new switch still no brake lights,
I don't have that model to check. Assuming that newer autos do have a pressure switch on the master cylinder ( like they used to back in my day) then I think someone will be along with the location or another idea.
If you have a pre2002 van look at f12 (20A fuse) in the interior fuse box, if its after 2002 look at F5 (10 A fuse)in the interior fuse box. If you have power from the fuse box you then need to check continuity form fuse to brake switch then switch to brake lights.
One of the other thing's to check is the earth put the indicator on get some one to press the brake peddle with IGN on see if the brake light flashes dimly feed back through the wiring
My 2002 m49 burnt out 2 of the black/white brake switches that was 5 years ago .I changed all brake globes to led and have reduced the load on the switch and never had any problems since
its a 01 model on left side there no side light
Yesterday 10:07 PM
Yesterday 10:01 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
