Threads: 2
Thanks Given: 1
1.6HDi with 79k has a squeal when moving off under load or on a hill, sometimes accompanied by a judder. Car changes up to second gear and squeal vanishes. Is this early signs of clutch failure?
Threads: 23
Thanks Received: 27 in 24 posts
Thanks Given: 31
4
My 14 plate does the same Squeal but no Judder.
Only does it as you say on a hill or under heavy load.
The following 1 user says Thank You to Hughzie for this post:1 user says Thank You to Hughzie for this post
• Gm73
Threads: 23
Thanks Given: 31
4
It had me concerned when I first started hearing it but I've convinced myself that given it wasn't even a year old when I bought it with less than 10k on the clock in April this year that it shouldn't be a major issue.
If your stupid enough to try and pull away without releasing the handbrake it will really squeal!
Threads: 29
Thanks Given: 67
20
It's an auto box, get it looked at by someone qualified there is no thrust bearing to squeal so it could be something or nothing. Are you sure it's not alternator belt slipping or something else ?
Thanks Received: 26 in 24 posts
Thanks Given: 52
(30-11-2015, 09:53 AM)ffrenchie Wrote: It's an auto box, get it looked at by someone qualified there is no thrust bearing to squeal so it could be something or nothing. Are you sure it's not alternator belt slipping or something else ?
actually, they are manual boxes...
63 plate Berlingo working hard.....
Threads: 29
Thanks Given: 67
20
05-12-2015, 09:39 AM
(This post was last modified: 05-12-2015, 09:47 AM by ffrenchie.)
(04-12-2015, 02:59 PM)ATL_driver Wrote: actually, they are manual boxes...
So is it a semi auto box, auto or is it a manual ? Is it a diy approach to get it fixed and does it have a thrust bearing? So Alistair could be right with the thrust bearing going through the clutch spring do you think ?
Threads: 15
Thanks Given: 46
5
Its a manual gearbox & clutch with automatic gearshift & no clutch pedal. Squeal could be loose belt or thrust bearing & judder could be clutch so needs looking at.
