52 plate 1.9 van gear stick
Hi, i hope i'm on the right thread, i've noticed that when i put the gearbox in 2nd, the stick touches the passenger seat, while messing about i found that while still in gear i could pull the stick toward me to it's proper position, there is a lot of movement in it, it's been up on a lift with the mechanic checking all mountings but nothing has come loose, the linkage has been checked with nothing out of place, even though i can get all gears, there seems to be a problem i hope doesn't get worse, any ideas please. thank you
(04-10-2015, 06:27 PM)Sabbath Wrote:  Hi, i hope i'm on the right thread, i've noticed that when i put the gearbox in 2nd, the stick touches the passenger seat, while messing about i found that while still in gear i could pull the stick toward me to it's proper position, there is a lot of movement in it, it's been up on a lift with the mechanic checking all mountings but nothing has come loose, the linkage has been checked with nothing out of place, even though i can get all gears, there seems to be a problem i hope doesn't get worse, any ideas please. thank you
Hi there mate
Did you ever find out what was wrong with the gearstick ?
this could be interesting as mines is quite sloppy
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
