Threads: 2
Thanks Given: 3
Yesterday while i was driving i changed from 4th to 5th gear when there was a crunching sound then no gears? The gear stick just floated around , have not got chance to get to garage but would like some info on what happened, is it gearbox done in or drive shaft maybe? Also what coat do you think i will be looking at ? .Thanks for taking time to read this.
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
Hi I have had this problem and how you have described it, it sounds like same fault with me it was a gear linkage a metal bar with two like ball joints and the bar just clips on, but it probably best to buy new part from dealer it was thirteen pound, a bit of a pain to fit if you havent got a good trolley Jack or lift but I suppose a garage would only charge an hours labour about thirty pound or so, but as you have described it don't worry its not the box. First time it happened to me rac managed to clip it back on at side of road but it happened again so bought new part, hope you understood this long winded message.
Threads: 41
Thanks Given: 82
6
I've only ever had a gearbox go one car (not a Citroen) and it basically crunched a lot and then didn't work after that. Is that whats happened to yours, or does the car still work?
The following 1 user says Thank You to Mike for this post:1 user says Thank You to Mike for this post
• whodafoxhat
Threads: 28
Thanks Given: 29
Hi again
Let me know how you get on the one that went on mine had a large hole onone side and a smaller one on the other with rubber in middle which had perished making it pop off
Threads: 2
Thanks Given: 3
Morning got it fixed , it was the linkage that came lose, my mate said it wasn`t as bad as he suspected he managed to put on another hole for bolting it together. It will do till i get the van back it is over 50 km away from where i live at parents home house for the cost of 40 euro(£35). So must see now will it start to affect the gear box in future? Thanks for your advice earlier Berlingo HDI, when it first happened i thought i would have to get a new van and keep this for spare parts. All the best.
Threads: 28
Thanks Given: 29
Hi there pal,
Glad you got it sorted and that it wasn't anything more major wrong with it, like I said earlier I temporarily fixed mine but it's best to get new part before it goes again[/align]
