Gearbox rattle, sometimes...
Hello all...
 I hope I am hearing things but I have noticed twice now that there is a bearing rattle from the gearbox..
 I have fitted a new thrust bearing and fork so I am confident they are not the issue..
 I fitted new brake discs and pads the other day and when I was working on the N/S, when turning the disc / wheel I noticed a bearing rattle in the box but not sure of where, then again I was manoeuvring around a car park and there was definitely a whine with clutch up, or down, so I checked the gearbox oil and it is fully topped up so no problems there.
 Is there a common bearing failure on BE4R gearboxes ? I see on fleabay that a 5th gear set is available, is this a weak spot ?
 The van is a 1.9D and I have covered 145k miles, the engine is still sweet and I look after this van like a child, it wants for nothing..
 Any advice please...
 Thanks..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
I would change the trans oil to synthetic & see what happens.Has the oil ever been changed.These boxes suffer from condensation.
Hiya, I replaced the oil with oil from Citroen when I bought the van 62k miles ago because the garage I bought the van from said they had given the van a full service but the gear selection was rough. When I heard the new noises I checked the oil and all is good.
I changed the Cam belt because the Water pump was leaking and found the idler bearing noisy.. So that is one less noise at least..
I have also noticed the Valeo Alternator I fitted 9 months ago is also rumbling so I am keeping an eye on that too..
I thought I had a rattling from the gearbox on mine for a while. Turns out the lower back heatshield had detached itselt from most of its mountings and was making a noise similar to dying thrust bearing at lowish revals. Could be worth checking out maybe :-)
M59 1.4 Petrol question
Today 11:37 AM
Cold Starting
Last Post: jboy012000
Yesterday 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
