Hi,
I have an ex-forestry Berlingo van. 2.0HDI my2006
as you can guess i have had to swap the rear axle. on pulling the old axle off it appears the previous owner has already swapped out the ABS equipped axle with a non-ABS axle.
so to confuse matters i now have a van that has ABS but the rear wheel bearings are non ABS.
I want to get the ABS functioning as it should so id like to find out is if i should buy the 29tooth wheel bearing or the 48 tooth wheel bearing?
Please help!
Please help!
