anyone know how to get in a locked berlingo least damage possible
so my fob only works when it wants and now has stopped working. I'm locked out of the van and the key is just turning in the lock any suggestions thanks
Sent from my SM-G920F using Tapatalk
Try changing the fob battery !?
Try one of the other doors with the key surely it works in one door. Are you a member of a breakdown company or try a locksmith they have little pump up airbags that you slide in the top of the door frame, then you pump it up so the frame moves out allowing a blade to get at the unlocking mechanism.
The dodgy geezers will already know how to do this it is the non dodgy chaps that don't !
  • ron
I managed it in end up and no changed battery last week that wasn't the problem so don't know what could be only drivers side door worked need to look at having all 3 locks changed I think. I just kept Turning key round and eventually must have caught the mechanism. Darent lock the doors now tho
You can get a lock set on fleabay and they are inexpensive and easy to replace.
thanks tom
(12-10-2015, 07:22 PM)Tomcat3 Wrote:  You can get a lock set on fleabay and they are inexpensive and easy to replace.
Yes i had to replace mine a few months ago.Cheap as chips from ebay,and literally 5 mins each to replace.
(12-10-2015, 06:55 PM)ciggy Wrote:  I managed it in end up and no changed battery last week that wasn't the problem so don't know what could be only drivers side door worked need to look at having all 3 locks changed I think. I just kept Turning key round and eventually must have caught the mechanism. Darent lock the doors now tho
As we have remote locking, the locks never get used. Mine does this. And one I had years ago as a company van too. Jiggle the key in the lock, and spray a bit of wd40 or similar in there, the lock will soon come back to life.
Sent from my D6603 using Tapatalk
Please, DO NOT use WD40 in the lock!
Use a proper Lock oil, preferably with PTFE additives.
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
