Threads: 2
Hi .picking up my berlingo van 1.9 on sat .then off to euros to get cambelt kit water pump rear drums and rear cylinders. Just got to get some to fit them .had a few quotes . £185 I thought that was a fair price .any other parts that I should change
Threads: 52
Thanks Given: 87
5
Hello Tony and welcome to the forum.
Thanks Given: 188
23
Hi Tony welcome to the forum good luck with the van. While you are doing the cambelt it may pay you to adjust the valve clearances. On high mileage 1.9s they have a tendency to close up and you need the camshaft out to replace any shims.
Are we there yet?????
Threads: 20
Thanks Given: 2,126
18
I agree with Tomcat.Do the valves check before.Then you only have to measure/replace shims at belt time.
Strawberry flavoured windows
Threads: 24
Thanks Received: 6 in 6 posts
Thanks Given: 38
well hello and welcome Tony
£185 sounds like a bargain for that lot to be fitted.
My local garage priced the water pump & cambelt £300 supply and fitted so if they do the brakes as well
sounds good
Threads: 67
Thanks Received: 716 in 613 posts
Thanks Given: 236
50
An extra hour labour max ( I've just done mine ) and well worth doing, if they need doing get them set towards top limit.
Serieal Berlingo owner
• ron
Threads: 67
Thanks Given: 236
50
Yes I like rattles too .... you are so right Ron !
As an aside Ron my " F " head has rattly valves and a bit too much of it so I'm currently rebuilding my spare engine ....
Spares are fruity .. £400 for a cam and another £300 for followers .... should' a got a younger one as their cam is £50 and followers at £90 ..... actually I prefer the F head to the OHV with max torque at 1500 rpm, nice !
• ron
