Threads: 3
Hi everyone so get in the van this morning fire up no problem get 100 yards down the road van goes into limp mode flashes up engine fault repair needed. Take it home turn it off and on again all fine Leave it running for 30 seconds without driving and same again. I'm getting fault code 2562. A little background 3 days ago I ran completely out of fuel it's worked fine since but just wondering if that's contributed? Any advice? Cheers everyone
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
16-10-2015, 08:15 AM
(This post was last modified: 16-10-2015, 12:11 PM by Col.)
Boost control valve. Check vacuum pipes and electrical conection, or may be the valve itself
Threads: 8
Thanks Received: 5 in 5 posts
Thanks Given: 17
Maybe a fuel filter / fuel pressure related, due to run out of juice.......
Sent from my 3geesus using Tapatalk( it's ifail)
Thanks Received: 26 in 24 posts
Thanks Given: 52
DPF fluid getting low? the codes are so vague
63 plate Berlingo working hard.....
Threads: 3
Thanks everyone il check these just home from work now wondering if I should clean out the egg I'm on 63000 miles?
Threads: 3
Ok so today I've changed the solenoid valve that's right at the back of the engine and also the one that's just below the turbo and it's made no difference at all I'm totally stumped could it be get related?
Threads: 23
Thanks Given: 50
29
There may be water in the fuel filter you pulled it through when you ran out of fuel messing with the fuel pressure
Threads: 5
Thanks Given: 3
19
Did you check the wiring and pipes or just change the valves?
