[Engine] Eloys fluid
Threads: 8
Thanks Received: 1 in 1 posts
Thanks Given: 1
Hi just wonder if any one can tell me how i would know if my eloy fluid needs to be topped up does a warning light come on the dash. My van is a 2011 1.6 HDI Belingo with 75000 miles covered. Thanks for your help
Threads: 23
Thanks Received: 501 in 458 posts
Thanks Given: 50
29
You will get a warning light on the dash around 100'000 mile's you can fill it up your self before hand so you don't get the light a way to make it last longer is to only fill the take when it's low it put's some in the fuel tank every time you fill up
Threads: 10
Thanks Received: 67 in 51 posts
Thanks Given: 20
11
One high mileage user on here, had his warning light come on, to refill his Eloys tank around the 85,000 mile mark. I will be buying a refill bag just before I reach that mileage (I'm currently at 36,000 miles).
Threads: 9
Thanks Received: 14 in 8 posts
Thanks Given: 1
(18-10-2015, 08:56 PM)CourierJim Wrote: One high mileage user on here, had his warning light come on, to refill his Eloys tank around the 85,000 mile mark. I will be buying a refill bag just before I reach that mileage (I'm currently at 36,000 miles).
I had to get mine refilled at 125k miles by Citroen Stealer, always run my fuel down until computor says 50/60 miles fuel left and then brim the tank.guess that's why I got to 125k.
Good luck.
Thanks Received: 26 in 24 posts
Thanks Given: 52
(18-10-2015, 09:06 PM)chrisl Wrote: (18-10-2015, 08:56 PM)CourierJim Wrote: One high mileage user on here, had his warning light come on, to refill his Eloys tank around the 85,000 mile mark. I will be buying a refill bag just before I reach that mileage (I'm currently at 36,000 miles).
Good luck.
I too run from full to empty on every fill up we got to 83,000 before it threw up a light, just after a low fuel level fill up it went into limp mode that was within a year and a half, and I know Jim gets through the miles even quicker than me
63 plate Berlingo working hard.....
Threads: 10
Thanks Given: 20
11
Yes Charlie, you were the driver I was thinking of, but I couldn't remember your Forum tag of ATL_driver! I don't fill up as often with my new van, as I used to with my previous one (i filled it every night), but I'm worried about moisture build-up in the tank, if I don't keep it well topped-up. I'm still clocking up the miles quickly. I've done 36,000 miles since picking the van up on May 1st this year, and added another 526 miles with my run today: Leeds to Bradford, then to Hull, then on to Dartford, then my last drop in Chelmsford, then back to Leeds!
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
The guys suggestions are about bang on for your fluid top up.
However, the fluid is calculated electronically, so the computer works out when the top up is required.
This means a reset on Lexia or Diagbox is unavoidable .
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• ron
Thanks Given: 52
26-10-2015, 10:23 AM
(This post was last modified: 26-10-2015, 10:24 AM by ATL_driver.)
(19-10-2015, 11:57 PM)CourierJim Wrote: Yes Charlie, you were the driver I was thinking of, but I couldn't remember your Forum tag of ATL_driver! I don't fill up as often with my new van, as I used to with my previous one (i filled it every night), but I'm worried about moisture build-up in the tank, if I don't keep it well topped-up. I'm still clocking up the miles quickly. I've done 36,000 miles since picking the van up on May 1st this year, and added another 526 miles with my run today: Leeds to Bradford, then to Hull, then on to Dartford, then my last drop in Chelmsford, then back to Leeds!
your mileage makes mine seem like I just pop down to the shops, the new 120 6Speed manual would be ideal for your routes, mines all country roads, very slow progress unless I'm driving from 5am haha
charlie
engine light
Last Post: angenieux
Today 10:44 AM
M59 1.4 Petrol question
Yesterday 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
