[Transmission] Very sloppy gear stick
2001 Berlingo van. 1.9 diesel
My berlingo van has a very slack feel to the gearstick which although does nothing to affect the gear changing
I find very annoying.
What is the possible cause of this and how easy is it to fix.
If you have any advice to help with this problem
Then please let me know
As I have the weekend off to fix this and a list of other bits on this old duffer
Its probably play and wear in the gear linkage to the box. Its a mix of rods, rose joint ball couplings, there are a few diagrams in threads on here to help you have a search. This is something like what you need but may not be the exact ones
http://www.ebay.co.uk/itm/CITROEN-BERLIN...xyOalTa3cR
  • petesta
(23-10-2015, 01:43 PM)Tomcat3 Wrote:  Its probably play and wear in the gear linkage to the box. Its a mix of rods, rose joint ball couplings, there are a few diagrams in threads on here to help you have a search. This is something like what you need but may not be the exact ones
I will have a look
I will have a look
I did readread on thithis site that there is a nut under the gearstick on the underside of the van that can comealso.
se also
Changing the gearstick rods is easy- just remove the air cleaner first for easy access.
Info display
Today 10:48 AM
P0691 P0693 cooling fan circuit problem
22-06-2025 01:36 PM
Brake problems again!
19-06-2025 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
