  • 12 Vote(s) - 3.5 Average
van keeps dying any advice greatly appreciated
I have an 03 1.9 berlingo 120000 miles on the clock, was driving to work the other day and all of a sudden she just died no warning lights or anything,had plenty of fuel in her, but battery was dead.
Put on a new battery fired up straight away, but 10 minutes down the road she died again with a flat battery, again no warning lights or smoke etc.
Towed her home and put a multimeter on terminals (with a charged battery) getting 12.5v not started and 14.2v when started.
when running if I put the window de-icer on can hear the strain on engine, but 14.2v leads me to believe the alternator is fine?
Im completley baffled and have tried 3 seperate batterys
Help before i put her out of her misery
Get someone to test the alternator properly, also check for a bad earth.
Im new here, thanks for your advice.
Will check earth, might just fit a 2nd hand alternator as there is one local on ebay for £20.
Must be the alternator as I cant see any other cause
if the van won't run with a flat battery, there's evidently not enough leccy coming from the alternator.
(03-09-2011, 05:38 PM)steve valentine Wrote:  if the van won't run with a flat battery, there's evidently not enough leccy coming from the alternator.
are there any write ups etc on here?
im on a jeep forum too as thats what i drive out of work and has plenty of write ups etc, obviously a piece of pizz to change but nice to have a read up incase any tool needed that i dont have.
need to sort me van as a 4 litre jeep for a 100 mile a day work aint working
Replacement of alternator needed.
does the ecu play a part here?
No. It's independend sourse. It controls by belt and voltage regulator
Engine management light
Last Post: cancunia
Today 12:50 PM
Juddering when pulling away
Last Post: magoo
Today 12:45 PM
» Replies: 19
Crankcase pressure reference values?
Last Post: saskak
Today 07:32 AM
Last Post: Tomcat3
Today 07:22 AM
» Replies: 708
Replacement TPS Sensor
Last Post: jimbo
Yesterday 10:34 PM
Powerflex Front Anti Roll Bar Bushes
Last Post: NANO_Vigo
Yesterday 08:52 PM
new member needing lots of help
Last Post: cancunia
Yesterday 05:44 PM
2.0 hdi abs no communication from abs ecu
Last Post: cancunia
Yesterday 04:48 PM
B9 Head Unit Upgrade
Last Post: dumdum
Yesterday 03:56 PM
Longshot... dash pics required
Last Post: dumdum
Yesterday 03:47 PM
