Threads: 5
looking for a fuse box diagram my radio isnt working or van starting,, i know its a fuse but i cant find the one i have a 2001 hdi berlingo
Threads: 5
all fuses are ok just need diagram
Threads: 5
would it be the bsi thats the problem
Thanks Given: 188
23
It would help if you could give a bit more information eg Did it just refuse to start, had you done anything to the van before hand, is the key being recognised, What power do you have in the van if at all.
That sort of thing then some one may come up with help.
Are we there yet?????
Threads: 5
Ok thanks, i went to put my radio in and it power didnt go on it,
So i went to start the van and it wont start,
only 2 lights on the dash was on was oil light and airbag,
Ive on indecators or miles on the dash plus no dash lights,
i Tryed all fuses they were Ok,
Thanks Given: 188
23
First make sure your battery is fully charged and ok, then check your wiring you could have shorted something out. Check all fuses in the bsi unit and fuses in the engine bay. If you have confused the electrics when you tried to swap the radio do a BSI reset. If you don't have remote locking skip that bit. If you had ignition on while working on the van you could have dragged the battery down and that will give you all sorts of strange readings on the dash. Do a search on BSI reset failing that turn everything off then disconnect the battery and leave for 15 minutes. Just work systematically through what you did and hopefully you will find the problem.
Threads: 5
Ive tryed a bsi reset but done nothing ,
battery is full,
all fuses are ok
Threads: 23
Thanks Given: 46
5
Did you try to fit a new or different radio?
You say it wont start, does it turn over?
If it was running before then you must have disconnected a wire somewhere or shorted one out.
How do you know the battery is full?
