First post here. Recently inherited a 1.4 2008 Berlingo. Looking for some wisdom…
Got the Heater Matrix replaced last week by local mech, came back with Airbag Light on. Stripped it down & airbag connector seems not to be connected, but does not seem to fit right in only place I can see that it should go. Auto – Electrician had a very quick look at it on Friday & said the same, he did not want to force it in.
Am I missing something here?? I don’t want to force the connection, hook back up the battery & have an airbag go off…..
If the connector doesn't fit then its not meant to fit there, don't force it and just ignore it !
There have been some recent posts about a mystery connector which doesn't fit anything near the steering column, they look like your one.
The consensus was it was for something that is not fitted to the berlingos in question.
The airbag light on is usually caused by the connector under the seat being disturbed and not always fitting right after reconnecting. The driver/passenger seats may have been removed for access to the underdash areas. Check that connector first.
