fitting double din head unit in 61 plate
Threads: 7
Thanks Received: 3 in 3 posts
ok guys looking to take the stock radio out and put a new one in my 61 ple belingo multispace....like the look of the double size one with the big screen ....also looking to put a dab and maybe bluetooth ....and would love some storage like internal memory hd .....what i need to know is my stock radio now controls some disply functions will this still be possible with a after market radio and any advice on what to get..has anyone done this can it even be done .....cheers guys and thanks in advance ....kev
02-11-2015, 03:00 PM
(This post was last modified: 02-11-2015, 03:13 PM by Andy2308.)
Hi Kev,
It can be done, I've just installed a Pioneer double din system, including DAB, sat nav & parking camera in my 12 plate XTR. I'll be towing a caravan so the camera is pointed down at the (removable) towbar so that I can back-up to the caravan with ease!
You will need the to use the Connects2 CTSCT003.2 interface lead if you want to maintain the use of the steering controls AND the system menu functions. Fit the Autoleads version and you won't be able to set the clock (I found out from experience)
You'll need to cut and remove the centre plastic bar below the original radio, this is easy to do.
I would also recommend fitting CT24PE11 fascia surround, it will tidy up the installation.
Only issue I have is that with the illumination wire connected, the stereo is permanently dimmed. It appears that 12v is supplied through this feed all the time the lights are off. I need to either take a lighting source from elsewhere or use a relay to sort the problem.
Pioneer AVH-3600DAB
When in reverse:
Camera:
Cheers,
Andy.
Threads: 24
Thanks Received: 80 in 59 posts
Thanks Given: 6
If you don't mind me asking... How does the interface lead actually allow the clock to be set? Cause that's usually done with the buttons on the original head unit.
I ask because I've also put a Pioneer HU in my car (albeit simpler single din unit) and have so far just put up with losing the stalk controls and the clock being wrong...
Threads: 23
Thanks Received: 501 in 458 posts
Thanks Given: 50
29
It mean's you can set the clock and so on using the stalk controls
With the interface lead I have it lets you access the system menu by holding down both volume buttons on the stalk for a few seconds. It is more fiddly to navigate than using the original stereo menu but the compromise is worth it!
Threads: 3
Thanks Received: 17 in 9 posts
Thanks Given: 6
4
05-12-2015, 09:04 PM
(This post was last modified: 05-12-2015, 09:17 PM by Lukemedia.)
Hi there
I've got a double din Parrot Astroid Smart fitted and have managed to set the hour on the clock by pressing the vol up and down together on the steering wheel control. I just can't find a way of navigating to the minutes though ?
Has anyone managed it ?
Threads: 0
(02-11-2015, 03:00 PM)Andy2308 Wrote: Only issue I have is that with the illumination wire connected, the stereo is permanently dimmed. It appears that 12v is supplied through this feed all the time the lights are off. I need to either take a lighting source from elsewhere or use a relay to sort the problem. Hi Andy, did you ever find a solution to this? I have the same problem with a Pioneer Head Unit, dimmed when the lights are off, bright when the lights are on, ie the wrong way around!
Jonathan
(11-06-2016, 03:14 PM)Jonathanp Wrote: (02-11-2015, 03:00 PM)Andy2308 Wrote: Only issue I have is that with the illumination wire connected, the stereo is permanently dimmed. It appears that 12v is supplied through this feed all the time the lights are off. I need to either take a lighting source from elsewhere or use a relay to sort the problem. Hi Andy, did you ever find a solution to this? I have the same problem with a Pioneer Head Unit, dimmed when the lights are off, bright when the lights are on, ie the wrong way around!
Jonathan
Yes Jonathan.
I used a changeover relay (has a normally closed as well as a normally open contact)
The feed from the lights is wired to the + of the relay coil, I tapped into the electric aerial / power amp output and wired that to the common terminal of the the relay and then the lighting feed to the stereo is wired to the normally closed contact of the relay.
Hopefully that makes sense!
Cheers,
Andy.
Threads: 0
(11-06-2016, 07:29 PM)Andy2308 Wrote: (11-06-2016, 03:14 PM)Jonathanp Wrote: (02-11-2015, 03:00 PM)Andy2308 Wrote: Only issue I have is that with the illumination wire connected, the stereo is permanently dimmed. It appears that 12v is supplied through this feed all the time the lights are off. I need to either take a lighting source from elsewhere or use a relay to sort the problem. Hi Andy, did you ever find a solution to this? I have the same problem with a Pioneer Head Unit, dimmed when the lights are off, bright when the lights are on, ie the wrong way around!
Jonathan
Yes Jonathan.
Cheers,
Andy.
Thanks for the reply, a bit too complex for my basic auto electric skills, but pleased you got it sorted!
J
Emissions fault.
Yesterday 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
