Threads: 2
04-09-2011, 10:30 AM
(This post was last modified: 04-09-2011, 11:12 AM by KEVSPREAD.)
hi there my first post and ive a problem :brickwall: is there anyway of setting the keypad to defaut ie 1111.
i once entered the wrong code a few times and had to wait 30 mins for it to reset and that worked fine,this time i stalled the van after starting up and tried to restart but after putting the code in i find the green light coming on but the red light is also on.
it wont let me change the code either as im only getting 4 beeps then the keypad doesnt respond...any help greatly appreciated...regs KEV
Threads: 5
Thanks Received: 76 in 45 posts
Thanks Given: 19
04-09-2011, 12:52 PM
(This post was last modified: 04-09-2011, 12:53 PM by BlueBlingo.)
Has your vehicle had an aftermarket keypad operated immobiliser fitted ?
If yes and it is faulty best remove it & go back to standard, trace wires back thru harness find out what it inhibits & connect wiring back to standard.
Or get a like for like replacement & fit.
If its declared on your insurance don`t forget to advise them of it`s removal if declared on policy !
What vehicle do you have ?
2003 Citroën Berlingo 2.0HDi Multispace Desire
Threads: 41
Thanks Given: 82
6
If it's anything like the keypad for the Xantia you can set the code. Wasn't aware of Berlingos having the keypad though.
To change the code for a Xantia you do the following Put your code in. Press C. Put new code in and press C again. It should beep and go to green. That's the only way to reset it I'm aware off. Did it a couple of times on my Xantia when one of the buttons decided it wasn't going to work as often as I wanted it to.
Thanks Received: 43 in 34 posts
Thanks Given: 11
Our old ZX had a keypad immobiliser - I think it was standard on the 'special edition' (Elation II) we got. As the Berlingo is based on the ZX, it seems reasonable that some might have the keypad - earlier ones maybe? I think Mike has got the procedure right. There's also a procedure for setting it to a service mode, so you don't need to give the garage your code. I wonder it that's what might have happened, as I think it might put both lights on to alert you. There is also a reset procedure, but I can't remember what it is. Have a look in the resources page on this site - there's a link to a site for manuals and you might find one there. If not for the Berlingo, try the ZX/Xsara/Xantia manuals.
The Bus II: 2019 XL Flair 1.2
