Replacement Key
My 2010 diesel MPV would not start. Everything else worked but it would not fire. The RAC suggested it was the chip in the key?? It sounds like I need a new key. Can I buy any key from eBay that is for use in a Berlingo? How do I code it? Presumably my local lock shop can cut the blank. Thanks
2010 Berlingo Multispace 1.6HDi - Chipped
No a second hand key will not work first you need to find out first if it is the key, you need someone with citroen/Peugeot software to check it. Or find yourself an auto locksmith in your area and they can produce and code a new key for you.
  • 60 north
I take it you do not have the 2nd key or the key card that came with the car when new? Are there any warning lights on the dash when it is cranked, as TC says above, see what any fault codes say, it could be something completely different to the key.
I do not have the 2nd key or the key card. When I turn on the ignition I get 'Anti-theft Faulty' After the remote was switched on and off loads of times, just before the RAC arrived I turned the ignition and the fault code was gone and the engine started.
Could be the aerial on the ignition barrel, loose itself or loose electrical connection. Having the ignition key on a bunch with other keys or metal fob can also cause problems.
It sounds like your key is ok, so a good car locksmith should be able to clone it.
Thanks. The fob is on its own on the key ring. This has only happened twice in 8 months of ownership. Based on the above, is it still worth me getting a locksmith to take a look?
You may have been parked near something that was interfering with the signal or as solent says could be the sensor ring around the column playing up or its connections. If it was me I would be getting a spare just in case I lost the only key as then you will be in big trouble. I think Timpsons are able to do basic programmed keys and remote programmed keys fairly reasonable. Try a local auto locksmith for a price.
I went to my local Timpson's and they quoted £55 for a basic key with chip. They tried to program the new chip but after putting my original key in their reader my key showed the 'Immobiliser Faulty' code. The new chip was therefore not copying anything and eventually they gave up.
Now when I put my original key in the ignition I get the fault code. I turn off and turn on and so far it has worked. Sounds like my issue has just got worse.
What do we reckon the next step might be?
hi. i would first get the car security pin, usually 4 digits..code for your car, this is what you need, you cannot program any keys without it..........there are virgin keys on about £21........ ebay.......take it to timpson's with pin code. or use diagbox to program keys..........should solve your problem........if its your key......
Take the cowl off the column and check the connections plug on the immobilizer ring then you really need to get it checked using diagbox software to see if its the key or immobilizer. Auto locksmiths have the equipment or you could try an independent citroen Peugeot garage or get the software yourself. There are members on here that have it and willing to help you. Also look on frenchcarforum as they have a list of members willing to help with software diagnostics.
Yesterday 12:17 PM
Last Post: wbchevron
Yesterday 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
